11 Second Club - Any m6 with minor bolt on's running 11s?
ffrh911
04-18-2011, 11:16 AM
Looking for f-body preferably. Has anyone, not just on here, made it in the 11s with just an exhaust and a couple other things? Just looking for the potential in these cars. Thanks!
JonCR96Z
04-24-2011, 02:16 PM
Check the fastest stock internal list.
With a good rearend anything is possible.
nmass399
04-25-2011, 04:47 PM
I am sure you could make it in the 11's with full exhaust and lid. I run in the very high 11's at 3500lb raceweight with ls6 intake, headers, cutouts, slp lid. mwc 9 inch with 4.11's and spool, lca's, torque arm, panhard bar, stock shocks and stock swaybar. Bogarts with 26x11.50x15 et street bias ply tires. M12 trans and steel driveshaft. It took a little bit of time before i got the car to where it would do that tho.
zacht
05-07-2011, 12:57 AM
^dang! i got about the same setup as you, only got a fast 92/95 and the mwc 9 with 3.98's. what kind of monster you running? i got a stage 3 in the garage i need to throw in.
im anxious to go to the track! i also got 100hp help from nitro dave's too!
also subscribing to see some more results!
OOOJOHN
05-16-2011, 03:19 PM
nitrous and tires will get a stock camaro in the 11's:D
blk/slvr02ss
05-17-2011, 11:38 AM
Yes they can but u will go threw a few rear ends,Clutches and maybe a tranny or 2 !!! Autos w/ bolt-ons and a stall r a lot easier to hit 11's w/ out breaking stuff !!!!Did u make it to PBIR Fri. night ?
nmass399
05-17-2011, 12:14 PM
I got a monster stage 3 with the chromeoly flywheel. It works very well and i have no less than 50 passes on it. I ran a 11.47 this past sunday with the car. I should be goin a little bit faster here in the next week or so.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
