Fueling & Injection - info needed for fuel lines
View Full Version : info needed for fuel lines
keith102371
04-18-2011, 05:32 PM
I bought the car this way, they cut the nylon fuel and connected it to the steel braided line with a rubber fuel line and clamps. :bang: what do I need to fix it right? i attached pics,
keith102371
04-18-2011, 07:12 PM
anybody?
MeentSS02
04-18-2011, 08:28 PM
So you need to go from the stock hard line (3/8") to the rails - looks like the only thing you need help sourcing is the adapter fitting that converts the GM quick disconnect fitting to the proper size AN fitting.
The cheapest fittings are made by Russell, so I'll list those part numbers - if you are running a -6AN line, you'll need either (only difference is color):
Russell 640850 (blue) or 640853 (black)
And if you want to run a -8AN line, you'll need either:
Russell 644000 (blue) or 644003 (black)
TransWS6Am
04-18-2011, 08:42 PM
Ok so, that line runs to billet fuel rails correct? It looks like you need this line, it is part of the FAST fuel line conversion kit for the f-body.
http://i271.photobucket.com/albums/jj139/transws6am/FST-54028G-KIT.jpg
OR maybe you already have that line and all you need to do is move your crossover line from the front (near the throttle body) of the fuel rails. to the rear of the fuel rails (near the firewall). Then take the line that your going to take off the rear of the fuel rails, and attach it to the front driver side fuel rail. Then all u need is the quick disconnect mentioned above to attach it to the hardline on the frame rail.
lol, I just confused myself with that one........
keith102371
04-18-2011, 08:48 PM
thanks!!! guessing i will need about 15-18 inches of fuel line too, happen to know part#s for them?
keith102371
04-18-2011, 08:51 PM
yes to the second part...lol
TransWS6Am
04-18-2011, 08:56 PM
u shouldn't need any extra fuel line, if you have the line that i circled, you will just need the quick disconnect.
TransWS6Am
04-18-2011, 09:03 PM
you need one of these, this one happend to be sitting on my kitchen table, lol.http://i271.photobucket.com/albums/jj139/transws6am/IMAG0177.jpg
move the cross over from front to rear.
Move the line that I assume is attached to the rear driver side fuel rail, to the front of the driver side fuel rail. Slap one of these quick disconnects on the end of the line and attach it to the hardline on the framerail.
keith102371
04-18-2011, 09:05 PM
well its about 18 inches from that fitting in the second pic down to hard line
keith102371
04-18-2011, 09:09 PM
so move this line to rear and the other to the front?
TransWS6Am
not once you move that line from the rear of the fuel rail, to the front of the fuel rail.
TransWS6Am
04-18-2011, 09:10 PM
100% correct
