98 Trans am with 2002 computer
Old 04-18-2011, 06:16 PM
silent102's Avatar
Default 98 Trans am with 2002 computer
I have a 98 trans am with 2002 computer. I rewired the 98 harness to work with the 2002 computer and everything works great except the fuel gauge is on full and never comes off it. I have HP tuners so I had bill at HP tuners do the 2002 chevy express van fuel segment swap on my 2002 PCM and then inverted the "gauge output" table like everyone recommended. Then I used "write entire" and still have not seen my fuel gauge come off of full. Keep in mind it stays on empty when the car is off then sweeps to full when the key is on and never moves off of full. Thanks for any help guys, Rob
Attached is my tune file.
File Type: hpt
Old 04-19-2011, 11:27 AM
silent102's Avatar
TTT, any thoughts? stuck in the water with this.
Old 04-19-2011, 12:57 PM
kevin kuether's Avatar
I did the same swap from Frost. He told me my gauge may read backwards also but it was something in the fuel gauge segment and it could be fixed. He told me if it was reading backwards he would have to change it in the pcm. Sounds like thats what yours needs. Mine reads ok so I got lucky on the first time.
Old 04-19-2011, 01:08 PM
bigboykilroy's Avatar
PM me your email address so I cna send you a fixed file to try. or I can post it back up here for you. There are a few 98's for some reason that are litttle bastards and like the table a little different. I know your pain im a 98 to a 2002 pcm as well.
Old 04-19-2011, 04:28 PM
silent102's Avatar
problem is the gauge has never moved. its not that it going backwards. I have try ed all kinds of values and can not get the gauge even to move.
Old 04-19-2011, 08:54 PM
Did the gauge work with the 98 pcm?
Old 04-19-2011, 10:31 PM
Frost's Avatar
Not 100% sure this will work since the segment used is different than the one that I use most frequently, but try this.
File Type: hpt
Old 04-20-2011, 09:48 AM
Make sure that you have the Dark Blue wire in the Red Connector on pin 38, that is the wire that controls the fuel gauge on the cluster.
Old 04-20-2011, 12:33 PM
silent102's Avatar
Tryed Bigboykilroy and Frost's tune files and have still had no luck with the car. Im going to check the wiring next and the fuel sending unit to make sure there hooked up right. Thanks for the files though guys, Rob
Old 04-21-2011, 07:51 PM
jerry lopaz's Avatar
i'm in the process of changing my 98 ta pcm to an 02 pcm. you said you had to
rewire for the 2002 pcm, what has to be rewired to make this work. also when you
get the fuel gauge working could you post what worked for you as i'm shure i will
have a problem with mine also. i have a 12200411 ecm from a 02 tahoe with a 5.3
and will use diablo predator for tuning after swap (predator wont work on 98 pcm's)
Old 04-22-2011, 02:45 PM
what you need to do is re pin the red and blue pcm connectors on the passenger side firewall.
Get a 2002 0411 fbody pcm, put in the segment fix.
install the new pcm done.
that is the short of the long. pm me if you have specific questions.
Old 04-23-2011, 09:04 PM
I_Need_Land's Avatar
sounds dumb but have you tried tapping on the cluster. my 98, until i tap the cluster, hangs up over past full.
Old 04-25-2011, 09:32 AM
Frost's Avatar
That's not MY tune file, it's yours; I just setup the gauge table the way it is in my functional 98>02 files. I don't know anything about the file or segment you used for the swap.
Old 04-25-2011, 08:13 PM
silent102's Avatar
It is a 2002 chevy express van fuel segment swapped onto my file by bill at HP tuners. Here is the original van file. Is this not what people use?
File Type: hpt
Old 04-26-2011, 11:10 AM
CalEditor@PCMCalibrators's Avatar
If you are still having problems please contact me. I have the software that allows the editing of the parameters. I have fixed several of these for guys that have purchased mail order tunes off of this board. I have worked with Bill @ HPT also. He uses one of my custom segments, but that car had a custom fuel cell.
Old 04-27-2011, 10:07 AM
did you double check you wires like I directed you to at the pcm connector?
Old 04-27-2011, 02:14 PM
silent102's Avatar
I haven't got a chance to look at the car yet since the car belongs to a friend of mine who I helped with the swap. First thing we do, I am going to check the wiring and the fuel sending unit then double check the segment swap is correct.
Old 04-27-2011, 03:21 PM
The fuel segments are built from the same template. That isn't the issue. The Van doesn't have the same Hz output to run the 98 F-body gauge.
Take a look at this thread
Quick Reply: 98 Trans am with 2002 computer
