Small Block & Big Block Chevy Specific - Big block chevy conversions
View Full Version : Big block chevy conversions
Bowlson
04-18-2011, 07:20 PM
:read:Can you do this conversion with the stock k member. If you mod the oil pan
Parasoth
04-18-2011, 08:10 PM
It's not the problem with the oil pan, it's the motor mounts. They don't make swap pieces if I am not mistaken, so therefore the only option is a full k-member.
shovel
04-18-2011, 08:15 PM
if you were trying to use a stock k-member really the only option would be to cut the mounts off box em off and run motor plates as im not that far into my bbc swap and havent picked up a block so im unsure if the mounts are located like a tradition sbc if they are i would imagine a lt kmember could work for ya. im going a mwc kmember no motor mounts and plating mine when i get there fwiw
Bowlson
04-19-2011, 12:37 PM
Thanks for the help
