Window Motor (already searched/sticky)
So my drivers window had issues going back up. It would be intermittent and in spurts. My assumption was that it was the motor. Went to Autozone and got the doorman (as eeveryone has sugggested in numerous threads) and replace it. It goes down fine but then the same thing still occurs going back up. What can I look into for this fix?
Thanks
Thanks
Most people say it takes less than an hour to swap out the window motor if you drill out the rivets. Check out www.shox.com and go into their how-to guides and there is a how-to guide in there with detailed pictures on how to do this.
Ws6store sells the autotrix kit if you want it.
Ungrounded Moderator
Thanks
Thanks
This sounds like a possible mechanical problem rather than electrical. I suspect you'll find the window regulator (the arms that move the glass) is binding. It could be as simple as cleaning and replacing the decade-old grease.
I had the exact same problem, bought 2 motors but never installed them. I did the following to fix my slow moving window, may not be the same for you. I removed the door skins, replaced all the weather stripping on the window sill and the mirror. Silicon sprayed the corner piece tbe is nearest to the mirroe. There are 2 locing nuts with brushes that slide against the window, loosened those. There are 2 nuts on the closest side to the mirror, loosened those. Powered on the car and ran the power windows up and down a bit to work in the silicon spray. Raised the power widows up, tightened the 2 nuts by the mirror, worked the window up and down and made sure it functioned smoothly. Locked all 4 nuts in place and that was it. Its not always a power window motor that everyone jumps to as the problem. Sometimes its just a siimple window adjustment that is binding.
Definitely read the thread and have never heard of a Doorman motor, I thought OP meant something else. So I see Doorman is a brand of motor...that makes more sense. Mrrman's idea might work too, I had the same issue as him. Trying the silicon spray is the easiest BUT it does wear off relatively quickly. Definitely pull the drivers side switch out and press the plugs on the back of it onto the switch to make sure they are making contact(had that happen once.)
Save the manuals!
Got to jump in on the lube. The thing to use is Syl-Glide. You can get it from Napa and will see it matches the stock grease.
Using silicone spray is probably OK as it's silicone based like the original stuff but it won't hold up like a good blob of grease.
