Msd wires tr55 plugs
I can turn a wrench but I'm not so good at knowing what brands are good and not so I need some help... Already have my headers on order and will receive them soon so I want to do plugs and wires while headers are off... Am I goin in the right direction here with the Msd 8.5 wires and the tr55 plugs? Once I change plugs and wires do I Need to tune?
Thanks for all the help guys
Forgot to add I'm at about 73000 miles on y 99 ta
no tune needed for simple plug/wires change, but once you do the headers you will need to tune out your rear 02's......did you get race headers or EGR/AIR headers?.....if you got race, like me, you can remove the air pump and egr valve, then tune them out......no biggie.....i went with msd wires also, but got the ac delco iridium spark plugs.....tr55 you're supposed to change about every 20-25k miles, the iridiums last a little longer......both do well though
98z... ok im with you now... i already purchased a k&n air filter about 2 weeks ago so im good on that..
98ss... i bought the tubes with emmisions so i will have AIR EGR, and your saying i will have to tune out the rear o2s? can you give me a little more info on that? i wasnt expecting anything like this lol
what if i just get the 02 extension?
the wires on your stock 02 sensors are fairly short, Bosch part # 13111 are a replacement sensor with longer wires, or you can re-use your factory 02's if you buy extensions.....i don't care for most Bosch products so i bought extensions from TSP, but some people have good luck with the Bosch ones.....Denso also makes a decent short wire 02 that works with the extensions, but i think AC Delco 02's (stock ones) are the best.....Delco part # AFS 97, AFS 98
