What 6.0 is the best?
looking for a 6.0 truck motor to put in my car..just wondering what years might be better?? probably wont be able to afford an lq9 so im looking at lq4's..thanks for the help
Jesse
Jesse
Ideally the LQ9 is better because it has higher compression for a NA build. The only way to get more compression out of the LQ4 is to run a small chamber head or mill the stock heads a lot. Both engines are good starting points. It just depends what you are looking to do with the motor.
Jon
Jon
Jon
Jon
