anyone know the pcm connector part numbers?
Old 04-20-2011, 05:03 AM
AutomagicLS1's Avatar
Default anyone know the pcm connector part numbers?
I need to buy a blue and red pcm connector gotta re pin for the 02 pcm in a 98. I know GM sells a whole package with just about every connector on the car but does anyone know a part number for each individual connector?
Old 04-20-2011, 07:25 AM
gofastwclass's Avatar
Interesting dilemma. I just looked at one and didn't see any part numbers on it but it did say "Delphi" on the red bits.
I know CompNine.com has lots of part numbers, did you try looking there? I can't remember the place people were talking about buying harness connectors separately but I've seen at least two.
Old 04-20-2011, 09:43 AM
bigboykilroy's Avatar
you dont need to get new connectors to do the pcm swap.
label all your wires on the connectors. R1, R2, R3, R4 etc.
then remove all the wires from the connectors.
Repin away.
Old 04-21-2011, 01:23 AM
MikeyZ's Avatar
check efi connection under connectors and pieces then select aluminum
http://www.eficonnection.com/eficonn...spx?ItemId=286
Old 04-21-2011, 10:37 AM
sweet! exactly what I am lookin for. Thanks man
Repin away.
The connectors off the roller I bought are corroded looks like some soap from the car wash got in there or something. Figure I'll just buy new ones
