Ping HKE, and other engine builders...break in oil?
I have just completed rebuilding and installed the LS7 in my corvette. I am curious about what oil to use for break in. It's my understading that Mobil 1 is the factory fill, so can I use it for break in?
If not, why not? Even mobil has info on their website that using conventional oil for a new motor is a myth. I do understand that their opinion might be biased.
Has anyone used synthetic for breaking in a new motor, or do you just stick to the tried and true convetional becuase it works?
I'm betting this topic has been beat to death, but I couldn't find much with a search.
Thanks in advance
Tony
Thanks in advance
Tony
LS1Tech Premium Sponsor
We use Joe Gibbs Break-in Oil, and supply 12 quarts of it with every short and long-block we ship!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
We used to do the same, and then Shell cut down the levels of ZDDP in their oil, and GM raised the price of the EOS....so Joe Gibbs made good sense/cents. We always had success with the EOS though!
__________________
That I do not know! I will ask him next time he comes through though!
__________________
Agreed, the first 6 quarts is just for a heat cycle or two, then gets changed and the filter cut open and inspected. The 2nd, assuming the filter looks good, can go a few hundred miles on average.
__________________
