Radiator
Old 04-20-2011, 03:05 PM
Animal323's Avatar
Default Radiator
Im looking to put a new radiatior in the car because the plastic on the edges of my stock unit is beginning to crack. I wanted to no if i should buy a stock one or upgrade to all aluminum one and if so were i could buy one. I saw an all aluminum becool one on ws6store.com and its $493 and it says manual trans next to it does that really matter? My car is a manual but if i go with another company would i have to specify my trans being manual? thanks guys.
Old 04-20-2011, 03:09 PM
Clyde H Frasier Jr's Avatar
I got a griffin radiator and yes you will have to let them know. Auto need transmission lines with radiator. I love my griffin, Summit, Jegs or Griffin themself, there in SC.
Old 04-20-2011, 06:35 PM
KILLERARMY's Avatar
You can also check into Be Cool aluminum radiator.
Old 04-20-2011, 08:31 PM
SOMbitch's Avatar
If you are not modded an LT1 rad is a little bigger and (1/16" IIRC) and will drop right in. I have a Howell Racing dual 1" core rad and had to cut some to make it fit and it is overkill for a stock/bolton motor...
Old 04-22-2011, 12:26 AM
chrisfrost's Avatar
Rock auto parts has killer prices on quality parts . You have a manual trans , if You had an automatic You would need 1 specifically for automatic (the difference is whether or not it has trans cooler lines for the automatic trans . With a car that has manual trans You can use either radiator , but a little better to use 1 without cooler lines with a mnual trans .
