v8 swapped t56 rx7 whining from trans?????
Old 04-20-2011, 11:34 PM
thefastlife's Avatar
Default v8 swapped t56 rx7 whining from trans?????
I have a 93 v8 swapped Rx7 with a t56 and i have a whining noise coming from below the shifter at least thats what it sounds like. It emits a noise heard in car and out and only sounds when any acceleration or load is applied. But as soon as clutch is pushed in it goes away or if no acceleration is given and even on decel it doesnt make any noise. It also doesnt make the noise in reverse. It does it in all gears and at any speed or rpm. It was making the noise so a stage 2 tick performance rebuild kit was done to the trans by a mechanic and the noise is still there. Does anyone know what this is its driving me nuts! Please help guys thanks.
Old 04-20-2011, 11:59 PM
bongva's Avatar
does it pop out of gear?
Old 04-21-2011, 08:49 AM
No it drives what i would say perfect. No real sign of anything wrong with it except that horrible noise.
Old 04-21-2011, 02:53 PM
calhoon's Avatar
Is there a body boot on the tunnel? If not , it could just be normal noise that would be blocked out by a boot.
Old 04-21-2011, 05:10 PM
no it is pretty much like i have a kenny bell in my trans under any throttle at all but clutch in or reverse there is no noise
Old 04-21-2011, 10:50 PM
jmd
jmd's Avatar
Did the Stage 2 parts including bearings?
What did the tech think of the trans. bearings especially at the front of the input shaft and countershaft?
This:
"only sounds when any acceleration or load is applied. But as soon as clutch is pushed in it goes away or if no acceleration is given and even on decel it doesnt make any noise." can be a characteristic of a poorly set up or worn differential as well. A mechanic's stethascope (cheap at HF) might help you pinpoint.
Old 04-22-2011, 10:50 PM
Walt Kowalski's Avatar
Does it clunk when you select any gears?
Is it slow to change on high RPM gear changes?
Old 04-23-2011, 12:43 AM
This:
Not sure what it looked like as this is a handed down issue from the previous owner. Could the sound from the rear end travel up to sound like its coming from under the gear shifter I even took the center console off to hear it better and it sounds like its coming from the trans.
As far as the clunking you ask...it kind of feels like there may be something from a dead stop that feels like a clunk from the initial stopped to moving movement.
Old 04-23-2011, 12:44 AM
I take that back maybe not a clunk sorry this is just so difficult to explain
Old 04-23-2011, 04:41 PM
I do hear a clunk sometimes when i let out the clutch after shifts. What im trying to explain is probably so confusing to you guys. Also at highway speeds the sound turns into a very high pitched whine that is very loud opposed to a deeper whine at lower speeds.
Old 04-23-2011, 09:46 PM
Come on people i know we have some people on here that could diagnose this in a heartbeat! PLease!!!
Old 04-23-2011, 11:23 PM
jmd
jmd's Avatar
Lightbulb
Just trying to be ironic?
Old 04-24-2011, 09:48 AM
bayer-z28's Avatar
You know, my buddy's T5 does it. He bought a built T5 from D&D. Nothing physically wrong with it, but I agree it does sound like he's got a KB under the hood. Always wondered the same thing. Maybe it's the gearsets. Helical gear-sets are supposed to be quiet. Depends on the tolerances though. Try changing the oil?
Old 04-24-2011, 07:46 PM
Subscribing
Old 04-24-2011, 10:11 PM
Sargeant Sh!tbag's Avatar
Im with you here..
If you dont want to take his suggestions you could go retard on it. Eliminate a rear/u joint issue so you can eventually get "A mechanic's stethascope" and isolate the problem area..
Pull the driveshaft out
Install tranny plug so fluid doesnt spew out
Put car in gear and throw it some Revs in gears
Then tell us:
Does it still do it?
Old 04-24-2011, 11:45 PM
Originally Posted by Sargeant Sh!tbag
Im with you here..
Then tell us:
I didn't say I wasn't going to take his suggestions I think what he was saying is they talked about a stethoscope and I said something about heartbeat.
Old 04-24-2011, 11:47 PM
Not sure if it was just coincidence but it seems to get louder while taking turns to the right I noticed
Old 04-25-2011, 10:46 PM
Any more ideas? I'm pulling the trans wed to check things out.
Old 05-03-2012, 06:18 PM
maxgee's Avatar
Find the problem?
Does it whine in 4th?
Old 05-03-2012, 06:26 PM
boostit5.3's Avatar
my buddy had a weird noise in his 2001 ws6 6 speed, we tried everything it ended up being the input shaft was all effed up... prolly from previous owner slacking in the pilot bearings replacement department... this noise kinda mimiced a release bearing noise
Quick Reply: v8 swapped t56 rx7 whining from trans?????
