Cleaning Electrical Connectors????
Old 02-21-2004, 09:05 AM
Nagash01WS6's Avatar
Default Cleaning Electrical Connectors????
Ive got a ton of coolant in the electrical connectors from doin a headswap. What kinda stuff should I use to clean them out????
Old 02-21-2004, 11:29 AM
Texas Terminator's Avatar
brakeclean
Old 02-21-2004, 12:50 PM
NoGo's Avatar
Electraclean is the best that I have seen. It is hard to find though. Be careful though, it will take your skin off
Old 02-21-2004, 09:23 PM
Moderator
jimmyblue's Avatar
I wouldn't use brake cleaner on "mystery plastics".
WD-40 will chase moisture out pretty well (that's
its original purpose, WD being "water dispersant").
Just douche them real good.
WD-40 should not be put into the airstream or the
engine oil though. Silicon is bad for O2 sensors.
Silicone spray is no exception.
Old 02-21-2004, 09:46 PM
taqwache's Avatar
dam i hope i dont have problems. i just reconnect them how they are and forget about it. if i were to worry about it, i would probably blow them out with pressureized air and use electraclean. you can find it in most auto parts stores.
