OE Wheels guys - what springs are you running?
Old 04-21-2011, 11:18 AM
t-rey's Avatar
Default OE Wheels guys - what springs are you running?
I have been eyeing the c5 17/18 deep dish wheels for my 96 Camaro. I am not a fan of a really raked stance, so my only real concern is if the bigger wheels out back will make it sit too high in the back for my liking. Either way, what springs are you guys running or do you recommend that give a good stance with these wheels?
Old 04-21-2011, 12:34 PM
SSCamaro99_3's Avatar
If you run the appropriate tire sizes, overall tire height will be equal, and the stance will be level.
Old 04-21-2011, 12:42 PM
t-rey's Avatar
Awesome, thanks for the reply
Old 04-21-2011, 12:44 PM
babbage1109's Avatar
Bmr. And if it's too high you can always do the heater hose mod
Old 04-21-2011, 02:00 PM
floodofnoise's Avatar
This is true, but wouldn't the front tire look thicker than the rear? Not sure how good that looks myself.
Old 04-21-2011, 02:04 PM
I run the 17x9.5 and 18x10.5 setup with a 275/35/18 and 255/40/17 and it's almost dead even. Yes the front is A wider sidewall but not noticeable from 10 feet away. Lol Look up tire calculator ingoogle and you can mess around with the size differences
Old 04-21-2011, 02:06 PM
www.rimsntires.com/specs.jsp
Old 04-21-2011, 05:30 PM
t-rey's Avatar
Right on - so the stance of the car stays about the same. Thanks for the link btw, I will be messing around with that when I get a few minutes.
Old 04-21-2011, 05:34 PM
Go with a 285 or wider. The 275 on a 10.5 wheel is a little narrow. If I could change it I'd go up a size
Old 04-21-2011, 05:35 PM
t-rey's Avatar
Yeah, I'll probably go with a 285 or maybe something a little bigger.
Old 04-21-2011, 11:46 PM
808z28camaro's Avatar
Lowered on sportlines running 315/30/18s out back
Old 04-22-2011, 12:47 AM
TXZ28LS1's Avatar
Damn thats a nice fbody!! I think white is the best color hands down.. i wish i would have went with white.
Old 04-22-2011, 07:29 AM
t-rey's Avatar
Very nice man. Did you have to use the bfh mod to get the 315s to fit?
Old 04-22-2011, 10:34 PM
Thanks for the compliments. Some mods needed to be done to make them fit, but the outcome is well worth it. BFH mod, Cut outer fender lip (didnt wanna roll and risk and cracking the paint), Grind bump stop bracket, 1/4" spacer, extended shank lugs (dont have longer studs).
Old 04-24-2011, 10:57 AM
Donohue96M6Z28's Avatar
Cutting the fender isn't the smartest move. That creates a sharp end that can cut the hell out of a tire. If you roll the fenders, its more of a rounded end, so instead of cutting the tire, it rubs the tire inwards. I've had rolled fenders on a few of my cars and never had issues with peeling paint. But the genious that rolled the fenders on my current car did a horrible job (before I bought it), and there is some paint flaking on the edge. You just gotta find someone with experience.
Old 04-24-2011, 11:24 AM
ta-stanger's Avatar
Damn my car set lower then that with sportlines. I ended up going with 295's on BMR springs.
Old 04-24-2011, 01:06 PM
I thought about that dude. thats why its body worked smooth. also it doesnt go anywhere near the tire. thats why you roll/cut, to get the fender AWAY from the tire. otherwise whats the use of rolling/ cutting the fenders anyway? hello!?! As you stated your paint was cracked from previous owner "rolling the fender". Hense why i didnt roll. its a gamble I personally didnt want to take. Ive seen many many cars with cracking paint due to rolling. its a hit or miss. as for experience, my good friend is one of the premier mod shops here. he has rolled/ cut thousands of fenders.
Old 04-24-2011, 01:17 PM
Yea when i first installed the springs i was wondering why my friends car with sportlines looked lower. I took that pic the day I installed the springs. they've settled a little lower now. I guess they needed to "break in"
Old 04-24-2011, 01:56 PM
Revcore66's Avatar
Do you have any close up pics showing the finished result of your qtr panel lip modification? Being a bodyman myself for 20 yrs, I'm just really curious to see.
Old 04-24-2011, 09:03 PM
808z28 Camaro -- you roll the fender because there's about an inch of a lip that is inside the fender. I dont know about you, but I use big boy 315s, that usually do hit the fender. But since theyre rolled, they don't cut them. I've had 7 fbodies and have gotten the fenders rolled on 4. All 4 that I've had rolled turned out great bc they were EXPERIENCED. The guy that rolled my fenders on the current car must have been a newb. Do some research on cutting fenders vs rolling fenders. From what I've read in the past, cutting fenders also weakens the quarter panel itself. Again, if you have an experienced person rolling your fenders, there will be no issues.
Quick Reply: OE Wheels guys - what springs are you running?
