Pontiac GTO 2004-2006 The Modern Goat
Trans Cooler Mounting
Old 04-21-2011, 01:58 PM
BlueMagicSS's Avatar
Default Trans Cooler Mounting
I have an '04 GTO I'm working on and I need to mount the B&M SuperCooler for the stall... anyone have any advice on which way to mount the cooler? I'm not sure if I should mount it top to bottom or side to side... and which hose should be the inlet and outlet. Not sure if it matters and the directions aren't completely clear.
Old 04-21-2011, 08:32 PM
JAX04's Avatar
You want to mount it after the radiator. I cannot remember which one is which, its been awhile, But an easy test,
run the car for awhile, drive it around and then as soon as you park it, feel the lines going into the radiator trans cooler, which ever one is "cooler" is the return to the trans, thats the line you'll want to tap into.
Reason being, since the radiator is only going to cool it to the temp of the radiator, why waste the ability of the extra cooler.
Mount it after that and enjoy! I choose to put it directly behind the driver side Grill with the "GTO" in it. Seems to work pretty good!
good luck man!
Old 05-02-2011, 08:48 PM
GoatPilot87's Avatar
Bump
Ive been wondering about this also. Are there any guys that can post some pics of their cooler setups?
Old 05-03-2011, 07:14 AM
CamaroAl's Avatar
We run a Derale Cooler part # 13950 fits in there pretty nice and has a fan also for help keeping the temps down more
Old 05-03-2011, 10:24 AM
massillongoat's Avatar
I mounted mine on the drivers side behind the bumper with L brackets folded down so it sits between the the bumper supports
Quick Reply: Trans Cooler Mounting
