weird noise when i disengage gear
Old 04-22-2011, 07:53 AM
sandbergz28's Avatar
Default weird noise when i disengage gear
I test drove a 02 z28 last night and it was going good til i almost got back to the dealer and when i pushed in the clutch and pulled it out of gear it started grinding I could feel it in the clutch pedal it would go away after I put it back in gear and let out the clutch happened a couple times not every time i shift and it was louder the faster you would go any info much appreciated thanks
Old 04-22-2011, 05:30 PM
anybody any input helps looking to buy a car soon would like to know if it is something to worry about
Old 04-22-2011, 05:55 PM
Vexzer's Avatar
Sounds like you can bargain the price of a clutch install off the asking price.
Old 04-22-2011, 06:19 PM
the only thing that worries me is if its the trany not the clutch its got 74000 on the clock so id be looking to upgrade the clutch anyways $500 for a clutch is easy 2000 for a trany not so much
Old 04-22-2011, 06:21 PM
Im new to the t56 and ls1 had a 94 a4 z28 lt1
Old 04-22-2011, 09:28 PM
FSTKMARO's Avatar
I second what was mentioned about your chance to negotiate the price. You say little about the problem. I am curious as to whether or not you felt the grinding at the shifter as well as on the pedal. Regardless, I think you will be fine with a new clutch kit. I recommend replacing everything including flywheel and thrust bearing. That is if you buy the car.
good luck
Old 04-23-2011, 07:27 AM
did not feel it in the shifter seemed to shift good it was like a vibration in the clutch pedal with grinding noise happened at a slow roll in first when i pushed in the clutch shifting between 1 and 2 once and between 4 and 5 once took it on like a 20 mile drive
Old 04-25-2011, 06:21 PM
anybody any more input
