Low_S-10
04-22-2011, 09:05 PM
does anybody know the grade of the aluminium used to make the valley cover? or what filler rod should be used when TIG welding a hole closed. im asking this because i want to shave the PVC port/square block off and fill the small hole in, also i plan on polishing the cover when done.
SATAN
04-28-2011, 10:41 PM
I'm willing to venture that it is NOT a 7000 series aluminum. I say that because if it is, it won't matter because you can't weld it.
If it is something else, (which is most likely) you can weld it with a 4043 rod.
Low_S-10
04-29-2011, 09:20 PM
ok thanks
