Drag Racing Tech - Whats the most RWHP cam only LS1 w/ heads please post up and track times
dnkynrbk
04-22-2011, 09:55 PM
Doing a budget build for my brother. We have a 99 Camaro with a stock ls1 with a T350 w/brake. Going to do a cam head only car.
Would like to know some set ups that work? What intake and Heads and best track times.
snake charmer
04-23-2011, 03:03 PM
bump for the most . have seen a lot of claims but not sure what is up to date .
00blacka4
04-23-2011, 06:23 PM
depends on the budget honestly, and dont forget about the intake, a good intake finishes off the combo....If theres no budget i would look into trick flow 225's or AFR, talk to Tony Mamo hes very helpful.....also depending the the stall/gear you guys wanna use have someone spec you a cam to match everything...good luck
xX-Z28-Xx
04-23-2011, 06:28 PM
this has got to be good....
dnkynrbk
04-24-2011, 09:52 AM
dam anyone
Firehawk441
04-24-2011, 10:12 AM
Hard to beat a T/F "AS Cast" cylinder head for the $$$. It flows 1% less then the CNC 215 for hundreds less. If you already own a set of 243's, having them ported by TEA would be even less $$$ with equally good results.
If you order the T/F's from TEA, you can have powdered Metal guides installed as an option and run stock rockers with no worries.
dnkynrbk
04-29-2011, 06:00 AM
so should i get the tfs you said just the cast ones. or has anyone played w/ the 799 ls2 head
blue99fbody
04-29-2011, 09:38 AM
Don't know what the most is but I have a buddy that did 500rwhp with a stock bottom ls1 11.7:1 Afr 205s pat g custom spec cam and mamofied 102.
dnkynrbk
05-01-2011, 10:47 AM
Im just going to either go witht he TFs or the afrs. 243 are like gold seems like to find. I am going to get a custome cam to go with the ported VIC and the accufab to match. I have did research and found they like like a 109 lobseperation.
chrs1313
05-01-2011, 11:26 AM
here is my turd...
http://www.ls1tech.com/forums/dynamometer-results-comparisons/1405540-522rwhp-440rwtq-a4-346-update-track-results-car-vid-4-10-11-a.html
would probably be upper 53x to low 54x..if it was stock 10 bolt/gear, m6, street tires rims...but i just care about how it does at the track...I do think it would be interesting to throw it on an engine dyno though, take out alot of variables...
will be 9s this fall if the track prep is there..ran 10.20 at 131mph in 3000ft DA, 60ft was a little weak too at 1.36...
dnkynrbk
05-03-2011, 06:51 AM
here is my turd...
sweet what intake and trans you running
chrs1313
05-03-2011, 10:02 AM
4l60e...fast 102
SSPerformance
05-03-2011, 07:45 PM
Dont worry to much about RWHP you need to make the car WORK.... We are 105 RWHP less the chris1313 and runs 9.98 but are car pulls 1.31 60s....
Zmg00camaross
05-04-2011, 10:28 PM
:hijack: ^^ what shocks are you running.
SSPerformance
05-05-2011, 08:45 AM
Qa1s in the front stange in the back
Higgs Boson
05-05-2011, 03:39 PM
I've got a bare pair of Lingenfelter CNC heads I will sell.
How much you want to give me? I can ship them on Friday.
tektrans
05-06-2011, 07:24 AM
here is my turd...
thats impressive. Lock up converter but still h/c a4 at 522 rw is sweeeet! Stock compression?
chrs1313
05-06-2011, 08:00 AM
yeah locked converter...spooled 12 bolt, 4.10s, 28" mt drag radials...
compression is around 12:1...
dnkynrbk
05-06-2011, 08:19 AM
Thats rocking down the track
chrs1313
05-06-2011, 10:45 AM
should go 9.8-9.9 this fall in the cool air...around 3000 raceweight so she is light :)
thanks for the props, car is street driven to the track everytime too
