High RPM idle when rolling in neutral after ported TB install
Old 04-23-2011, 10:39 AM
udienow's Avatar
Default High RPM idle when rolling in neutral after ported TB install
I just installed a ported throttle body and now my car idles high when rolling. When driving at whatever speed, if I put the clutch in or pop it in neutral the car will idle at 1800 RPM or so, it will stay at that RPM until i come to a complete stop and then it will finally drop to like 900-1100 rpm which is still higher then before at a stop. Is the throttle blade not fully closing? The new TB has all the mods done including epoxy mod if that matters. Any ideas?
Old 04-23-2011, 12:19 PM
ZHAWK154's Avatar
can try disconnecting battery for a few mins. reset ecm
Old 04-23-2011, 12:39 PM
sjsingle1's Avatar
Originally Posted by zhawk154
can try disconnecting battery for a few mins. Reset ecm
++100........after i did my TB install in took about 10 mins to relearn idle speed......until then it was about 2000 rpm
Old 04-23-2011, 09:37 PM
udienow's Avatar
found the problem. It ended up being the PCV hose that connects on the left side of the front of the intake manifold. The rubber had a hole in it. Taped it up, car idles great. Will replace it from dealer on monday
Old 04-24-2011, 06:49 AM
sjsingle1's Avatar
that little hose from the PCV to the manifold nipple is no longer available....unless you buy the whole assembly....use a few inches of 3/8 hose.........ask me how i know
Old 04-25-2011, 08:34 PM
MEGATRONSS's Avatar
Mine did the same thing, took about 20 min for it to correct itself.
Old 12-15-2011, 10:26 AM
JamRWS6's Avatar
Bringing back up since I'm having a very similar problem. I've previously replaced the entire PVC assembly and have swapped the TPS and IAC sensors from the original TB to my ported TB which has been on the car for 80K+ miles without issues. I've also cleaned the TB and that didn't help. Car has about 118K on it.
The car idles high in neutral until coming to a complete stop...sometimes. Usually in the mornings it will act like this; other times it will go away and the car will idle completely normal which leads me to believe it isn't a vacuum issue.
Anyone had any issues around the MAF? Other ideas? I have access to an EFI Live scanner so I have the ability to look at some parameters. What kind of readings should I be getting from the MAF at idle?
Thanks
Quick Reply: High RPM idle when rolling in neutral after ported TB install
