Double Cone 3rd Gear Differences MM6 / MN12
Old 04-23-2011, 01:46 PM
jmd
jmd's Avatar
Post Double Cone 3rd Gear Differences MM6 / MN12
These carry the same tooth count. Why do they carry a separate part number? What am I overlooking?
There's a bevel of the gear teeth on the MN12 3rd gear at the teeth edge nearest the synchro. There are slight differences in the non-critical surfaces such as the additional groove on the non-synchro end of the gear. I don't see those as critical. Anything else I checked was within 3 or 4 thousandths height.
Old 04-23-2011, 03:32 PM
85MikeTPI's Avatar
Are they actually from an M12 and MM6 ? If so, you'll find the OD of the MM6 gear larger because it meshes with a different number of teeth on the MM6 countershaft.
Old 04-23-2011, 03:35 PM
jmd
jmd's Avatar
2006 Z06 and GTO yes.
Thanks. Will measure.
Quick Reply: Double Cone 3rd Gear Differences MM6 / MN12
