700rwtq and up+ What Clutch are you using?
Old 04-23-2011, 02:37 PM
Choose1's Avatar
Default 700rwtq and up+ What Clutch are you using?
I plan on around 750rwhp/700rwtq and I know I need to upgade my clutch (currently Centerforce DFX). What I'd like is some input from guys in this power range and up on a good clutch with good street manners, i.e. pedal feel, chatter, holding power....
My car will mainly see daily street driving with maybe 5-10 1/4 mile runs a year.
Some clutches I have been looking at are but not limited to:
-Spec 3+
-Tex Z or X?
-Mcleod RST or RXT?
Which ones are good?
Which should I stay away from?
Jerry
Old 04-23-2011, 10:25 PM
Choose1's Avatar
Come on people, don't be scared!
What Clutch are you running?
How much power are you making?
Why do you like/not like it?
Old 04-23-2011, 10:36 PM
Gordon0652's Avatar
RXT in my build, not running yet...
Old 04-23-2011, 10:56 PM
Plaugher4's Avatar
Im running the monster stage three and i love it. I know im not pushing 700 plus hp but so far i can say that this is one hell of a clutch. Im sure plenty of others on here will say the same. A stage three is rated at 700 hp but you might look at a stage four or higher.
Old 04-24-2011, 12:55 AM
Choose1's Avatar
I'm really leaning towards one of the McCleods, the RST is cheaper and should hold my power level but I should probably go with the RXT to be safe.
I hear the Monsters are more like a On/Off switch and not very good on the street (Stage 3 and up) The price is surely appealing in comparison though.
I've had some recomendations for the Spec twins but have also read some horror stories on Spec!!!
Old 04-24-2011, 01:50 AM
Mygoat1's Avatar
I will be running a Mosnster level 5 for my build its currently being finished up at SNL as soon as I feel the clutch out I will let you know. 04 Goat with a 408/F1-A build hoping for 750+rwhp.
Old 04-24-2011, 02:34 AM
Plaugher4's Avatar
I dont feel my monster stage three is on/off at all. It is a tad heavier than factory but it has that nice solid feel to it. The clutch can be slipped but a little chatter will be felt if slipped excessively. I feel it is a very streetable clutch. I am using the monster 18 pound flywheel as well. I also liked how my monster required no shimming at all. The whole clutch assembly fell into place. The fit and finish is great with this package. Depending on how soon you plan to purchase a clutch i can post a vid of how street friendly my stage three is.
Old 04-24-2011, 06:14 AM
LPE 403's Avatar
RPS Twin
Old 04-24-2011, 09:28 AM
bayer-z28's Avatar
Just to push someone a little farther; I've had my McLeod Single (An master) since 06 and not one problem with it. Bites plenty hard when you snap the clutch and a smooth engagement. No chatter at all. I'd do a McLeod clutch again in a heartbeat.
Old 04-24-2011, 01:08 PM
BarneyMobile's Avatar
I agree,
I run the RXT and its been great so far. My car is a daily driver and cuts 1.4 60's on slicks. My car makes just shy of 650rwhp on spray.
Old 04-24-2011, 02:23 PM
Choose1's Avatar
What FW's are you guys running with your RXT's. I know McCleod says you can run your stock but mine has some heat spots and I'd rather not deal with resurfacing and shimming.......
Old 04-24-2011, 04:58 PM
I have a spec flywheel with mine. I got it when it was on sale. It will work with any factory style flywheel.
Old 04-24-2011, 10:00 PM
Sargeant Sh!tbag's Avatar
Ram 10.5R Twin
Not making the power to push this clutch though. Works well for ~650 lol. Im thinking Texas Speed was running one of these but not positive..
Old 04-25-2011, 08:28 AM
1CAMWNDR's Avatar
Textralila Exo-Skel twin. Daily Driven on a stock short block with heads and cam and now with the 421" motor. If you assemble it correctly and learn how to drive with it it will work very well for years. Mine has been in for @4 years now (not including the time down with the busted motor).
Old 04-25-2011, 10:34 AM
thesource's Avatar
I would run a twin disc setup period. That much torque with a single disc setup is going to have crappy drivability.
Old 04-25-2011, 11:18 AM
SPEC-01's Avatar
Our Stage 3+ is rated to over 900lb.-ft at the crank and is very drivable. Of course if you want to go with a twin then any of our Super-Twin options would easily meet your needs. Let me know if you have any questions about these and I will be happy to assist you. Thanks!
Old 04-28-2011, 08:02 AM
blue99fbody's Avatar
I've had monster level 5, monster 11", and spec 5 and all have held ~750wtq for me. Monsters drove great on the street for me
Old 04-28-2011, 08:54 AM
'Trust''s Avatar
Obviously a different application, but T56 clutch is T56 clutch. I have a Spec 3+ in mine, held lots of bottle with 879rwtq no problem. It will be staying in with the turbos until it lets go.
Old 04-28-2011, 12:22 PM
FMX05's Avatar
How did the 11" compare to the level 5 on the street? I'm planning on ~800whp and drive it on the street a lot.
Old 04-28-2011, 02:26 PM
no diff on the street at all only diff i noticed period was that i had the 18lb fw with the 11" compared to the heavier one with the 5
Quick Reply: 700rwtq and up+ What Clutch are you using?
