FiFdYnUtz
04-25-2011, 12:54 PM
hey guys, i recently picked up a moser 9" rear with 31 spline axles, 4.11 spool, lca relocation brackets, etc...and i currently have 100% stock rear suspension/driveshaft/tq arm/lca's and i was wondering if there is anything i'll need to change to accept this rear, i have the 1350 u joint already and will be ordering SFC's soon...will my stock peices be okay? any tips will be appreciated, thanks! Tyler
Ryans99ls1
04-25-2011, 01:13 PM
to use the lower holes on the relo-brackets you may need adjustable LCA's other than that you should be good.
BlkBird2000
04-26-2011, 01:24 AM
I would also purchase an adjustable panhard bar so you can adjust your red end to be centered. Not needed I don't think but would be a good investment. Panhard bars are cheap as hell to.
Bob@BruteSpeed
04-26-2011, 05:25 AM
You can reuse your stock components, although the stamped steel stock torque arm is prone to bending approx six inches ahead of the rear. Here is one of my favorite torque arms to use, as it gets the front of the torque arm off the tailshaft of the transmission. http://shop.brutespeed.com/BMR-TPU001-Trak-Pak-Torque-Arm-Kit-With-CB001-BMR-TPU001.htm Bob
