How much injector is needed
(Estimated HP) x (BSFC) / # of cylinders x Max Duty Cycle
Example- (600 HP) x .6 / 8 x .80= 36lb per hour @ 43.5 PSI
(Brake Specific Fuel Consumption)BSFC= Pounds of fuel burned to support 1HP for 1 hour. Gasoline Engines will typically be between .4 -.7 depending on how efficient the engine is.
Standard Injectors are Tested at 43.5 psi
We have a few fuel calculators on our website you can use to play around with different power goals, fuels, system pressures, etc.
http://www.deatschwerks.com/fuel-calculators/
Looks like a 42# would be a good size for what you are looking to do on spray.
