Need Help with Ignition lock cyliner replacement. URGENT
hey guys. I just got to my buddies house and the plan was to replace the ignition lock cylinder. Well the write up we had was for the ignition switch. Any and all help on how to get this thing out (cylinder the key goes into) would be greatly appreciated. We are dead in the water right now.
Thanks
Mike
Thanks
Mike
u have to have the key in the ignition, turn it half way, and u should be able to pull the ilc out. youtube has videos on how to take it out.
http://www.wikihow.com/Replace-the-I...-a-1995-Camaro this should help
http://www.youtube.com/watch?v=Yz_BTfL4SFc video for ilc removal on a pontiac GTO
GL hope that helps
GL hope that helps
Save the manuals!
Here's a write-up with pics. If you go all the way through this, you just need to remove the bolt holding the cylinder in, thread the VATS wire back up through the column, and it will slide right out. (Be sure to pull a string, etc. back up through the column so you can pull the new wire back down again.)
https://ls1tech.com/forums/general-m...mn-repair.html
