drag racing your ls4
well with racing season upon us i thought it would be cool to share some tips and tricks on drag racing your fwd i will throw the obvious one out there with dropping your front tire pressure
has anyone put coil spring spacers in the back springs, and how did they work for you?
1/8th tank of gas or less
45psi rear tire pressure
remove driver side headlight
remove crap from trunk
roll into the throttle and stay calm
never hot lap
open hood between runs, and keep the engine off as much as possible
don't try to be the fastest one out there. Work on beating your own times.
Stage deep. Meaning... stop as soon as the second stage light; lights up.
Turn off headlights and other battery draining items. (Just by turning off my day time running lights, I gained .5mph)
Do not lower the front tire pressure! Search on line for the reasons why.
Do not! Do long burn outs. Just back up to the water box (stay out off the water) set the parking brake and floor it for a few seconds. Just long enough to clean the tires off.
Then do a couple light throttle stabs to check traction before staging
never hot lap
never hot lap
never hot lap
Ok, now I have heard it both ways... leave front tires alone and drop to 25 psi.. I am now cornfused...
The tire and burnout thing will depend on what tires you have and rim size, etc. You really need a good contact patch and tread compound will decide how hot they need to be.
When my SS was naturally aspirated with a few bolt on mods, I would keep the car in 2nd gear through the traps for the quickest et's. 13.0 was my quickest when the car was n/a.
K&N, Hogan catless DP, Magnaflow catback no resonator, LS6 yellow valve springs, 1.8 HS Rockers, TF pushrods, Diablo Lew tune, Ported LS4 intake manifold, poly dog bone mount, and slicks was what it took to get there.
