General LSX Automobile Discussion - Fluctuating RPM in Motion
View Full Version : Fluctuating RPM in Motion
Rushin
04-27-2011, 09:57 AM
Well guys, figured I'd get your opinion. :D
Problem: While driving, around 2k rpm, the motor will literally surge a few hundred rotations back and forth, basically before the shift point, then it will shift like normal. I'm guessing that the transmission might be low on fluid, but I can't tell; the dipstick is good and covered in a film of fluid, almost like it's splashing up the tube, so I'm beating myself up trying to figure this out.
Mods: Performabuilt 2 4L60, 3300-stall, my own trans tune (never had problems with it before the Performabuilt), and of course motor work, tune, etc.
Let me know what you guys think.
mikey67
04-27-2011, 10:29 AM
Does it do it before lockup? It sounds like it could be torque converter shudder. My Grand Prix does this a bit.
Rushin
04-28-2011, 09:33 AM
I thought that it did, but I played with it this morning and it does it when it's locked up as well, so I now doubt that it has anything to do with a transmission. Still can't imagine what it could be.
BTW: It does it only at part throttle, so it maybe it's a slight misfire?
SOMbitch
04-28-2011, 02:50 PM
Check for a pending p1870 code. Sounds like the torque convertor clutch (tcc) going out. When it gets worse you will eventually have hard 1-2 shifts. There is prolly some stuff on it in the tranny section as it is a pretty common 4L60e problem....
mparker916
04-28-2011, 04:32 PM
Is it actaully doing it or just reading it?
It could be a cross over issue...
Rushin
04-30-2011, 06:47 PM
Even with a brand new TC and trans? It started doing it the day I put the trans in. The 1-2 has always been a bit on the rougher side, but barely, and I've yet to pull the "Component Slipping" code. HPTuners isn't picking anything up.
SOMbitch
05-02-2011, 12:06 PM
Don't know what to tell you. From your description it does sound like a failing TCC but if it was resleeved when rebult and no code not sure...
Rushin
05-10-2011, 10:52 PM
Alright guys, I got an update: it's definitely a misfire at exactly 2500 rpm; no trans. problems. Sounds much simpler now, yet I still can't trace it. No plugs fouled, O2s are switching properly, MAF reads well, all metering sensors are seemingly good. Think it might be the tune? All input is welcomed!
