Can you replace bumpstops?
just out of curiosity, is it possible to do this? I have 315/35/17 tires and they had to shave my existing bumpstops so they would fit. Say if i want to put on reg rims/tires is there any problems with shaved bumpstops? (even worse case scenario) If so, can they be replaced?
I don't think there will be an issue if you go back to stock rims. They usually shave the width not the height.
Good luck finding them to replace, they are discontinued. Some people are using a jeep replacement bump stop and it's supposed to work. I got a 3rd gen one, solid rubber and better made, from a junk yard I'm going to try b/c mine are toast.
