is the ls9 timing cover different than ls2 or truck engine?
LSxGuy widda 9sec Mustang
If you want to use the LS9 cam in a gen III style block (Pre '07ish trucks) you will need the LS2/LS3 front cover w/cam sensor, an early 1x LS2 upper timing gear and a camshaft sensor wiring extension.
The LS7 and LS9 timing covers stick out further since they have a longer crankshaft and lower timing gear for the Corvette's dry sump 2-stage oil pump.
Thank you. The cover I bought came with the Cam sensor and everything else i need and I had already bought a 4x ls2 sprocket. So now I guess I just need to find me an early ls2 timing cover. The sensor is the tan one... it will work with the 4x sprocket right?
