Programming PCM for Swap
At the risk of getting this thread locked, (I looked at the stickys and the tuning 101), I need to know the basics on programming the PCM for use in swap. It's an LS2.
It seems the discussions on tuning concentrate on getting the best performance. I just need to get the engine to run properly by turning off the required parameters, unused sensors, etc and whatever else that needs to be done in a typical swap.
I have never done this before so I am greener than green in this respect.
Thanks for your patience!
Larry
Larry
Sure, no problem. I didn't think we would get so detailed so quick!
I don't have a tuner yet. Diablo seems popular.
I'm not sure by "which PCM?" It is the original one that came with the engine.
I believe the O2 sensors are the only ones that are left. Any other emission sensors have been removed. I have a list of codes from the company that have been turned to allow for these removals.
The engine is factory stock out of an 06 GTO. It is DBW throttle.
It is going in a 69 Camaro.
Manual 6-speed transmission.
A little more background info...
The harness has already been modified by Current Performance. The PCM was already tuned/programmed by them to work in a swap. Certain features that aren't being used any more have been turned off.
I am having issues with it backfiring when starting it. After a few tries, the backfiring stops and the engine starts and runs fine. The check engine light comes occasionally too.
I want to be familiar with this tuning/programming process so I can troubleshoot it if necessary.
