bias or radial
Old 04-29-2011, 11:02 AM
mterveen's Avatar
Default bias or radial
m6 car with 15x10 weld rts, low 500s rwhp turbocharged and 4ch rearend with 3.50 gears. need a rear strip tire. i would like to keep my stock z06 275/40/17s radials on front for now to keep it simple. want to be able to drive 20 miles to the strip on the tires.
i read that et street radials r hard on a m6 so should run bias ply. however, can u mix a radial front and a bias rear? i can pull the abs fuse when i have the tires on if i have to although would be nice to not have to by running a 275/50/15 or something similar in height. would a 28inch be better for my setup and how wide? not lowered currently.
