Tools & Fabrication - need help finding a tool to hold the crank in place..
1sicws6
04-29-2011, 05:41 PM
The Ls shop I use to work at had a tool that bolted up in place of the started on a ls motor which worked great for torqueing down pulleys but I cant find it does anyone have a clue who sold it? thanks
BADD SS
04-29-2011, 09:20 PM
Kent-moore flywheel lock tool. Dont know the part # though.
camarof41_383
05-05-2011, 07:31 PM
http://www.etoolcart.com/flywheelholdingtool-j-42386-a.aspx
I want one of these but keep hoping someone will make a tool to do the same thing for cheaper.
Pocket
05-12-2011, 05:47 PM
Simple
Take an old flexplate and cut a small section off it, then weld it to a piece of scrap steel and drill two holes in it
Mike52
05-13-2011, 09:00 PM
Simple
Pocket, I like the way you think!! :D
LS1MCSS
05-14-2011, 07:24 AM
Just make two small brackets to bolt this on where the starter goes.
http://cgi.ebay.com/ebaymotors/UNIVERSAL-FLYWHEEL-LOCKING-TOOL-92-107mm-/140492756388?pt=Motors_Automotive_Tools&hash=item20b60555a4
Pocket
05-15-2011, 06:31 PM
$50-100 vs free using old scrap
Answer is simple in my book
Gray86hatch
05-16-2011, 10:01 PM
http://i1012.photobucket.com/albums/af247/gray86hatch/3c1dbf86.jpg
screw a bolt in the block bellhousing hole or use the bellhousing
Tim
01ssreda4
05-19-2011, 12:22 AM
Kent Moore tool is better..........:jest:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
