Headers installed and new exhaust pics
Old 04-30-2011, 01:35 AM
DavidGXP's Avatar
Default Headers installed and new exhaust pics
Cutout is getting installed on Monday.
Old 04-30-2011, 04:48 AM
flippincamaro's Avatar
Looks good, should sound a lot deeper too
Old 04-30-2011, 06:12 AM
Andrew91PGT's Avatar
Its hard to tell in the pictures, but did you go with stock rear section of the exhaust?
What brand that cat converter is that? Any sound clips?
Old 04-30-2011, 09:19 AM
ramairetransam's Avatar
exhaust looks greet but , why are all the joints welded ? Shouldn't you have clamped some or had a flange on some point so if you have to take some of it off or down .
Old 04-30-2011, 10:57 AM
DavidGXP's Avatar
It's very deep and sounds badass
It's 3" up to the bend. The rear section is the GXP magnaflow kit
I should of had a collector ring welded in. DT recommends welding the collector to the stock cat, so I'm not to worried
Old 04-30-2011, 02:12 PM
1CL3ANSUP3RSPORT's Avatar
Engine bay looks good,how much did the headers help out???Any noticable difference?
Old 04-30-2011, 02:22 PM
DavidGXP's Avatar
Loss of torque down low while cruising around, at WOT after 4500 it pulls very hard. With a full tank of gas and 2 other people in my car I ripped off two 4.95 0-60mph runs last night shifting at 6500. (dashhawk) Car weighs 3860 with me in it so I was pushing 4200 last night.
My trans is on its way out. Shifting like **** and not wanting to go into 4th gear. The torque converter is getting sloppy and it slips going into 2nd while driving round.
Old 04-30-2011, 03:52 PM
Do you feel the stock manifolds were better for your build,or the headers were a better option?
Old 04-30-2011, 05:01 PM
DavidGXP's Avatar
The headers are much better at WOT. My part throttle loss of power can be blamed on the loss of back pressure at low RPM.
I will be having 3.69's with a 3000 stall converter installed real soon. This should bump the RPM up so the engine will be closer to it's sweet spot.
headers kick *** just take some getting used to. My car is not as snappy down low, but is much more responsive above 4000 RPM. Keep in mind that when our trans shifts, the engine never falls below 4000 rpm. Headers with 3" exhaust really pulls hard.
I just can't stand the flex couplers making noise when I accerlerate. The new headers are supposed to have had this issue fixed. I bought an older set new in the box. So this is why I'm having problems. Plus.. I had the exhaust shop add a flex tube before the cat. Sounds like a leak, depending on throttle positions.
Update: 5/29/2011
The throttle response is back better then ever now... Just had to get re-tuned and give the chump..uter a chance to re-learn. The freaking coupler rasp is still there and it's annoying. I'm going to have the exhaust shop lower the crossover pipe and replace the coupler. Gotta make room for the 90mm intake/TB combo.
Old 04-30-2011, 05:33 PM
ImpSS07's Avatar
This is good to know, cause I wanted to go to a 3" setup and go to a 3" cutout from my 2.5".
Have you been re-tuned yet? Do you think that has anything to do with the low end loss?
Old 04-30-2011, 05:41 PM
DavidGXP's Avatar
It's not like I can't fry the tires with ease. I'm just talking about when cruising around town, I can notice a slight loss.. It's really not bad..
Yes.. I've been tuned. I even tried to go to the track today but there doing a bike only deal.
Scary fast now.... after 80mph Tons of torque steer.
My camshaft was spec'd for headers and was worth every penny!
Old 04-30-2011, 05:44 PM
ImpSS07's Avatar
I plan on getting spec'd by Pat G, when I get the cash. But I also need to do the intake swap first.
Old 04-30-2011, 08:52 PM
vroom_vroom's Avatar
if you are not going the header route would the 3in down pipe and 3in exhaust get you any value for your money?
Old 04-30-2011, 10:12 PM
DavidGXP's Avatar
With a stock engine. I'd just use the Hogan catted downpipe with a Magnaflow exhaust kit. You won't pick up much buy going to 3" all the way back. More like lose a bunch
Old 04-30-2011, 10:14 PM
thats what i thought just hate the magnaflows sound...............spintech.........yea
Old 05-01-2011, 02:32 AM
1BAD06MCSS's Avatar
You did not get in on the group buy? I thought you did?
Old 05-01-2011, 10:56 AM
So your saying 3" from headers back to y then 2.5 out thru muffs,is the way to go?Sorry David just trying to figure out how i want my exhaust re-done.I thought goin 3" from collector into 3" highflow cat thru 3"res into one 3"muff to the back,any thought on this setup???
Old 05-01-2011, 11:48 AM
DavidGXP's Avatar
I was in the group buy but got tired of waiting for DT to give me a call (wich I still have not recieved) So I bought some new in the box headers from another memeber.
With headers, 3" from the collector into dual 2.5" would be the best set up for street/strip use. Gotta run a cat to be street legal. 3" all the way back would be overkill.. Plus ground clearance and fitment would be a real problem. Not to mention expensive.
I'm 3" into 2.5" single, and then dual 2.5"
This is a little restrictive up top so I'm having a cutout installed before the cat on Monday.
The exhaust shop told me that the single 2.5" isn't that bad since I'm using a long section of 3" (Over 50" of pipe LOL)
By time the exhaust reaches the 2.5" single, the gas will have had a chance to slow down.
Old 05-01-2011, 12:46 PM
Sadden's Avatar
I asked my exhaust shop about 3" from the headers back (with dt headers) into duel 2.5" and they said that dual 2.5 would be a restriction....
Cause you know 2 2.5 in pipes wont outflow a single 3 inch pipe
And yknow i can outflow a 3 inch pipe right now.
Old 05-01-2011, 08:38 PM
I thought running 3" out 1 muff would be the same as two 2-1/2" muffs out.Might just run the 3" into 2-1/2" out then
Quick Reply: Headers installed and new exhaust pics
