Tony Mamo 102 w/ stock heads ?
Old 04-30-2011, 09:33 AM
I write checks with my mouth that my ass can't cash
00blacka4's Avatar
Default Tony Mamo 102 w/ stock heads ?
i have sent the money for my MAMO intake on my SI car...the only thing im worried about is the intake ports being way bigger than the heads, especially with being ported now...im afraid this is going to cause turbulence and power loss...i will be takeing the intake apart to see how it matches to the heads when i get it...and will post a ton of pictures of this mamo intake when i recieve it.
post up some opinions
Old 04-30-2011, 10:20 AM
bayer-z28's Avatar
The manifold ports are actually quite small so they can be ported to fit almost an set of heads. Depending on Cathedral or rectangular, of course.
I'm running ported 243's and they line up almost perfectly.
And there's a bunch of pics in here too.
https://ls1tech.com/forums/generatio...02-thread.html
Old 04-30-2011, 11:27 AM
00blacka4's Avatar
ahh...we will see hopefully i dont have a huge lip to create turbulence from the manifold to the head transition
Old 04-30-2011, 01:47 PM
brian_rs/ss's Avatar
you shouldn't. most of the porting is done a little up stream of where the mani meets the heads. unless they have the heads there to port match.
so you are bone stock heads? what cam?
Old 05-01-2011, 08:09 AM
00blacka4's Avatar
stock heads and cam...may sound stupid to put something like this on there but im maxing out my setup and need all the help i can get....we will see what it does pictures/dyno sheet comming soon
Old 05-01-2011, 10:16 AM
Mike Morris's Avatar
You should have a gain even with the stock heads since you have an LS1. Upgrade to a 02 and up Z06 MAF and 98 MM lid too if you will go into the motor in the future.
Old 05-01-2011, 10:30 AM
chrs1313's Avatar
you will be fine...A larger intake does not hurt the numbers...I have flowed a few at work...The most important shape is the farthermost inlet...Needs to be a smooth bellmouth funnel...
So bigger on the intake vs heads > smaller on the intake vs heads...
i picked up 20rwhp with the 102 & ls3 valves vs a 92...
If you have an ls6 intake to might see around 5 or so rwhp, if ls1 intake it will be double digit gains...let us know how it does...
Old 05-01-2011, 01:24 PM
Captain Double Post
BOBS99SS's Avatar
Sounds overkill to me on a si car lol,but at least it will be there for once you go h/c. Would like to see what you will pick up.
Old 05-01-2011, 04:03 PM
00blacka4's Avatar
he said he was going to go conservative on the exits of the intake so it was better with my stock heads...basically im adding ARH 1 7/8 and taking off the hooker 1 3/4 shitty headers (i looked into the collector and the primarrys were just smashed in there and looked like ***.....takeing off the ls6 for the mamo 102/102, and adding electric "race pump" meziere waterpump....hopefully get me 15 to the tire through an unlocked auto...
Old 05-03-2011, 04:38 AM
Navy02ss's Avatar
I can actually answer that question for you come Monday. I have an appointment on the 9th to have Thunder Racing swap my LS6 intake, stock TB, and SLP lid for my Mamofied 102mm LSXr intake, Vengence P&P 102mm TB, and FTP 104mm lid. I am still running stock heads and cam. I do not expect anything spectacular from the install. This is just preliminary for when I decide to do heads and cam.
Old 05-03-2011, 10:04 AM
chrs1313's Avatar
keep this thread updated...
Old 05-03-2011, 10:13 AM
lemons12's Avatar
Was interested when we talked... I'm In for results.
Old 05-03-2011, 10:27 AM
I am curious what you get as well. What MAF are you running still the SLP?
Old 05-03-2011, 04:47 PM
00blacka4's Avatar
^^^ that isint me...but i would like to know what that guy gained
Old 05-03-2011, 06:11 PM
mean_greenZ's Avatar
Yea you probably should look into a 85mm or tsp 100mm Maf to complement that setup or go with a SD tune.
Old 05-03-2011, 06:25 PM
00blacka4's Avatar
already has an slp 85 and FTP 98 lid
Old 05-03-2011, 07:02 PM
Navy02ss's Avatar
At the moment, I am running the SLP 85mm MAF with my setup. After the intake swap I will be dropping the MAF for an SD tune. This is based on the recomendations of Thunder Racing who suggested that if I were going to go with a 102/102 setup I would have better driveablitity with an SD tune rather than an MAF tune.
Old 05-10-2011, 05:37 AM
Navy02ss's Avatar
Before I begin, I need to send out some thanks. Thank you Thunder Racing for your excellent customer service and quality work. Thank you Tony Mamo for your astounding port. Thank you everyone and anyone that was involved with this swap.
All pulls were conducted on the Mustang Dyno at Thunder Racing on 09MAY2011.
The heads and cam are stock.
Base Line Information:
Intake: Stock LS6
TB: Stock LS1
MAF: SLP 85mm
Lid: SLP
Bellow: SLP Smooth
Baseline Run: 322hp & 317tq
Intake Swap Modifications:
Intake: FAST LSXr 102mm (Mamofied)
TB: NW 102mm (Vengence P&P)
MAF: N/A
Lid: FTP 104mm
Bellow: 4.25" Silicone Hose
Tune: Speed Density Tune by Thunder Racing
Post-Swap Run: 340hp & 330tq
Net Gain: +18hp & +13tq
All other modifications listed in my signature were present during both the baseline and post-swap run.
Sorry for the crappy photos. All I had was my phone and I had not slept in 30 hours. Overall, I am very satisfied. My acceleration is more responsive and the sound the intake makes when it goes WOT is glorious. Enjoy the results.
Attached Thumbnails Tony Mamo 102 w/ stock heads ?-dnyo-chart.jpg   Tony Mamo 102 w/ stock heads ?-img00107-20110509-0756.jpg   Tony Mamo 102 w/ stock heads ?-img00111-20110509-1600.jpg
Old 05-10-2011, 06:59 AM
00blacka4's Avatar
these results...make me ******* happy thank you for sharing !!!!
Old 05-10-2011, 09:18 AM
Intake: Stock LS6
TB: Stock LS1
MAF: SLP 85mm
Lid: SLP
Bellow: SLP Smooth
MAF: N/A
Lid: FTP 104mm
Wow that shows this intake can work well on a si car(though I am sure the SD tune has a lot to do it with it as well). Nice job! Did the car have a tune on it before the intake mods?
Quick Reply: Tony Mamo 102 w/ stock heads ?
