LS4 Performance - Kinda dumb tie rod question/help.....
rvd9431
04-30-2011, 12:08 PM
Ya, Im havin trouble with the lock nut on the outer tie rod end........dont have air tools, only hand tools. I bought a c-clamp vise lock pliers, the stud still spins with the nut. Tried using my vise lock pliers on the bottom of the stud while turning the nut, stripped my vise lock pliers and destroyed the bottom of the stud. Any other suggestions? Already broke a ratchet and a hammer, so im not having fun right now.
Andrew91PGT
04-30-2011, 01:55 PM
I assume its where the tie rod end goes into the steering knuckle right?
Do you have any gap at all between the spindle and tie rod end base? If you can get at least a sawzall blade in there you can just cut the tie rod end.
Andrew91PGT
04-30-2011, 01:57 PM
Or you could just cut the stud flush at the bottom of the steering knuckle and hammer it out from the bottom....
rvd9431
04-30-2011, 03:51 PM
im trying to put it on not cut it off
Panther427
04-30-2011, 04:00 PM
i wonder if you got something missing. like cotter pin or something
rvd9431
04-30-2011, 04:52 PM
........no, there are no cotter pins, the rod is spinning with the nut, I just stood on a bigass bar while someone tried to tighten the nut, and it still spins, im at a loss, gonna have to get it towed just for this dumb shit i dont have any impact tools
MonteSS8707
04-30-2011, 05:49 PM
U need an oxy accetelene torch, heat the nut till its glowing orange, and break it free from the inner tie rod.
rvd9431
04-30-2011, 11:46 PM
im not trying to take the outer off the inner, im trying to take the lock nut off the outer tie rod end, if I heat up that nut, bye bye plastic, ill need a new tie rod. I gave up after trying to use hand tools all day, I put a big ass 5ft tube on there and stood on it while someone else tried to wrench the nut back on, STILL spun, so Im getting it towed to a mechanics house where hes got a full shop in his garage tomorrow so he can spend all of 5 mins takin it off, thank god for nationwide roadside assistance plus
