"How to use a Megasquirt"
Old 04-30-2011, 03:30 PM
badchev's Avatar
Default "How to use a Megasquirt"
I have searched the website but canot find any threads on Megasquirts instals,...I see threads where they use them ,...but no one has done a start to finish (with Pictures) "How to use and instal a megasquirt." Even the Megasquirt web site is confusing.......
Old 04-30-2011, 08:19 PM
robbyredneck's Avatar
i considered it but when you weigh the flexibility and support of the stock pcm's it was a no brainer. buy hpt or efi and feel the love. megasquirt looks really good if you have little options but it's hard to argue with the general.
Old 05-01-2011, 06:26 PM
themachasy's Avatar
What he said. I built a megasquirt and ended up getting a stock PCM and harness, its just a lot easier and its OEM. Look at the results from HP tuners and EFI live and you'll see. Unless you really like tinkering, the oem ecu is the way to go. GM put a LOT of R&D into it and its great we can use it.
Old 05-04-2011, 08:34 AM
TTLS1GP's Avatar
x3
I run a MS on one of my other projects and I can say that it works but for this application, the stock PCM has many capabilities using HPT.
Old 05-05-2011, 08:00 PM
trav-tech's Avatar
I like my Ms. It does everying I need it to. And still has way more options left. Boost control, fan control, anti lag etc.... I don't really have any experience with hpt. Does it have the capability to auto tune your air fuel ratio off of a wideban o2 input?
Old 05-05-2011, 08:03 PM
not exactly but you can set your scanner up to plot error and adjust based on recorded data. can you control a gm trans with ms?
Old 05-06-2011, 11:01 AM
trav-tech's Avatar
Ms2 and micro squirt and gpio board can all be used to control 4l60 and 80e trannys. Can be tied to ms3 on can bus. They may add the whole thing to ms3.
Can you set up 2 or 3 step launch limiters with hpt?
Old 05-06-2011, 11:23 AM
not that i know of.
Quick Reply: "How to use a Megasquirt"
