jasonz28camaro
04-30-2011, 09:17 PM
installed my new 383 and had to take it to the shop because the motor was running bad. the car was backfireing because the lifters were bottoming out and not filling with oil or something??? the shop told me that the topend was not getting oil to it. they tried a few things and decided to give me the car back because they could not figure it out...
i took off the manifold and rented a priming bit form Autozone. I started t to prime for 5 min and nothing still with 60lbs of oil pressure. I took out each lifter individually and saw oil traveling threw the lifter galley at a good velocity, almost enough to reach the other side, is that good enough??? i can see the lifter very slowly allowing oil to pool on the area where the puchrod would sit and thats about all. my drill is a Dewalt 18v.
I was told maybe the freeze plugs fell out in the front of the motor but i pulled the timing cover back enough to see them sill in place, they said if they were out my oil pressure would be low too and it is not.
The lifters are LS7 and they came right out of my old block straight into my new motor. they are all still soft and not allowing my valves to open all the way. should i get new lifters and try to prime again??
