Notices
WTB - Damaged or cut Wiring harness, camaro or firebird- Need Connector, pic inside
Old 05-02-2011, 12:19 AM
Jimmy P's Avatar
Default WTB - Damaged or cut Wiring harness, camaro or firebird- Need Connector, pic inside
The two connectors that I need are numbers 36 and 37 on this diagram. They are the two that go under the dash through the firewall. They are called C230 and C220, but are only F-body specific connectors.
Anyone have any damaged or chopped up F-body wiring harnesses? I purchased a harness from someone on this forum and two connectors are broken. I looked at EFi connection but they dont have these connectors listed..So I figure if I bought a junk harness I can cut off the two connectors that I need and be good to go..Anyone want to help, please!
Old 05-02-2011, 12:49 AM
robsquikz28's Avatar
gm dealer should have them Jim!! YOu should be able to get them there with no issues
Old 05-02-2011, 01:30 AM
Jimmy P's Avatar
Hey Rob I will use the dealer as a last resort. If I was to buy it from them it would be just the connectors, and would need to repin them. I honestly have no idea how to do that. I woudl rather just get the connectors with pigtails and splice them in.
Old 05-02-2011, 10:27 AM
gcouse7's Avatar
Default harness
pm sent
Old 05-02-2011, 12:21 PM
steve000's Avatar
search by characteristic at EFI, I have purchased those connectors from there before,
