coolant crossover on back of heads instead of front?
Anyone ever put the coolant crossover tube across the back of the heads instead of the front?
Wondering if functionally it will serve the same purpose? I have a fuel pressure regulator mounted up front and would like to put that crossover in the back and plugs in the front but I'm having a difficult time finding info as to if this will still serve as a steam vent?
Thanks for any info ahead of time!
There are threads about this. Unfortunately, not all threads are easily found. You cannot substitute the rear for the front. The fronts need to be tied together & then run to a high point on the radiator, radiator top hose, top of water pump or high radiator auxilary box. If you leave the fronts plugged, the tops of cylinder(s) 1 & 2 will run hot. Engine is higher in the front than the rear.
My 06, 6.0 only had the front ones and the rears plugged. I was thinking about drilling and tapping the plugs and running braided with an fittings. I've heard so many opinions on this, I just figured it wouldn't hurt to have front and rear.
That's MISTER MODERATOR
The front of the block gets the cooled water from the water pump first, meaning the front of the heads gets the cooled water first. The rear of the heads gets coolant last, it's already picked up some heat.
I say it's more important to have steam ports on the rear of the heads rather than the front.
The LT1 engine added ports to the rear of the heads.
These ports also help bleed air from the system.
