School me on huc lobes
I got a cam spec'd out using huc lobes..this is the first time i heard of it..so someone school
Me plz..
Its for a lsx 4** with l92/ls3 heads
Me plz..
LS1 Tech Administrator
They are a high lift endurance lobe that give outstanding valve control with larger, heavier valvetrain. Although they are not as fast as LSL lobes, they will often out-rev them by 500 rpm and make much better high rpm power. When you see dyno sheets crash pretty fast above 5800 rpm, it is usually valve control related. The HUC lobes will often cure the valve control woes. Think of them as a modern marine lobe. Good stuff in the right application.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
"The HUC series hydraulic rollers are very smooth designs intended for high rpm use with heavy valves. These are very similar to the Xtreme Marine
™High Lift Lobe series but are slightly more stable."
From CompCatalog, pg 433
