What kind of gauges are you guys using
What kind of gauges are you guys using with your conversion. Do you have pics.. How did you set everything up?... I am using the stock Camaro gauge cluster...
I would like to know this too.
I have seen some cheap Dolphin brand gauges on ebay, but it seems too good to be true when the autometer and classic gauges are twice the price.
Also, has anyone use speedhut.com gauges?
I used the stock guage cluster that is in front of the steering wheel in my 1968 Camaro. The 5" electronic Autometer Antique beige guages fit perfect. I also put the other 4 guages on the center console where the stock square ones went. There are pics of them in my garage on this site. I hooked everything up electronically since the engine already has all the sensors on it. I wanted the conversion to look as close to stock as possible.
I have Dolphin gauges except the temp guage, that is autometer, Dolphin said theirs wouldnt work with the autometer sender I put in the pass head. They work great, great price. I did have to hook up my speedo to the wire off the trans though, not the supplied one from the PCM
