Generation IV Internal Engine - whats the correct way to install a oil pump
z28rich
05-03-2011, 12:09 AM
I need to change a oil pump on a ls2.whats the correct way ?
Rich
GluMaker
05-03-2011, 12:13 AM
Correct way? You may need to be more Specific. Like step by step or priming question?
z28rich
05-03-2011, 12:48 PM
do I just slid it on the crank and torque it down or do I have to check for being centered?
Gray86hatch
05-03-2011, 04:21 PM
I would make sure it is centered. They do it that way at the factory for a reason.
Tim
crainholio
05-03-2011, 05:17 PM
Rich
Correct way:
Buy a manual or search for an accurate procedure, then follow it.
There are measurements to be taken w/ the pump cover off, to ensure the pump housing is properly centered and the eccentric has the right spacing. Not something you want to trust to luck.
z28rich
05-04-2011, 12:07 AM
so does anyone know:eyes:
GluMaker
05-04-2011, 12:28 AM
what is the Year ,Make and Model? I will try to get you specifics from alldata. Last time I tried to send an Alldata page it didn't work but I'll try again.
GluMaker
05-04-2011, 12:40 AM
PM sent to Z28rich.
4U2BNVS
05-04-2011, 03:18 AM
You have to have equal amount around it. have to use a feeler gauge, but ive heard you can put it on and loosely tighten and and turn it over about 4 times and it will be centered, then it doesn't take as long to check with a feeler gauge. I cant remember the exact thousandths it is though
irnwkrkev
05-04-2011, 05:56 AM
^ I did it that way. Installed it hand/snug tight, spun the crank a few times and torqued it up. Haven't had any problems and the oil pressure is fine.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
