Puff puff
Old 05-03-2011, 01:44 PM
johnsontyler05's Avatar
Question Puff puff
Hey guys.... I have a 2001 SS camaro and was messing around with a bike, which we were racing around a little bit. He told me when I shifted through my gears white smoke came out of my exhaust... is this normal or is something wrong?
Old 05-03-2011, 01:47 PM
HoLLo's Avatar
Due to the crappy stock PCV system we have, that happens. Old oil vapor is pulled by vacuum from your valve covers into your intake manifold, and it's probably just burning some of that. Could be other issues, but the PCV is known for stuff like this. Not saying this is a permanent fix to that, but look into the 04+ LS6 Valley Cover modification. Will prevent oil being blowing into your intake manifold.
Old 05-04-2011, 12:46 PM
will this have long term effects at all?
Thanks
Old 05-04-2011, 01:01 PM
HoLLo's Avatar
As far as oil consumption, YES. I used to add a whole quart in between oil changes, and seriously I do not add a drop anymore. I started checking my oil very regularly after I put in the valley cover..
Negative effects. NONE.
Old 05-04-2011, 01:04 PM
RobRomero's Avatar
Interesting. Can you post the link for the write up please?
Old 05-04-2011, 01:07 PM
I haven't noticed any larger amount of oil being consumed.. thanks! I'll look into it.
Old 05-04-2011, 01:10 PM
HoLLo's Avatar
Like I said, I'm not saying this is your fix-all, but definitely something to look into. That puff could easily be due to burning up some oil that is getting spat into your intake.
