Electric power steering?
Old 05-03-2011, 03:23 PM
raymond mckinney's Avatar
Default Electric power steering?
I been thinking about getting a Race Electric water pump and doing a Electric steering pump out of a Camaro or G6 or something. Has anyone done this? If so got any tips or pictures?
Old 05-03-2011, 03:59 PM
MM98's Avatar
Way more trouble than its worth.. You would have figure out some way to make a column out of a cobalt, g6 or malibu work in your car. The electric motors are bolted up to these colums & require a control module to operate them. You would also then have to get one of the racks from one of the cars listed & fab it up to complete your project. Not to mention the electric motors & modules are very problematic & are not cheap to replace.
Old 05-04-2011, 07:27 AM
Idk if im going to try it but found a pump for $75 off another vehicle that requires two bolts to hook up and two custom lines for our style rack fittings and a hot wire and ground. Found several a-bodys with set-ups like this.
Old 05-04-2011, 08:47 AM
MM98's Avatar
Hmm, are you talking about an aftermarket style electric pump that still pushes fluid? Because the factory GM electric steering has no pump or fluid.. Just uses a motor & module mounted on the side of the column that power assists the intermediate shaft to rack.
Old 05-05-2011, 07:07 PM
Stancel's Avatar
There are tons of articles about road race cars using electric power steering pumps. The most commonly used pump for a budget project is from a Toyota MR2. The 2001 and up are more desirable. If I remember correctly they have brushless elctric mottors which will last a very long time. I personally chose a pump from a 2004 Mazda 3 because I got a smokin deal from a local junkyard. All you will need is custom lines and the know how to wire it up.
The options you suggested require changing your steering column where the MR2 or Mazda 3 simply replace the stock pump.
Here is some reading material if you plan to go that route:
http://www.evalbum.com/tech/mr2_powersteering.html
http://www.honda-tech.com/showthread...ht=ehps+redone
Old 05-06-2011, 11:46 AM
shepss217's Avatar
hmm, that's worth thinking about, mines whining like a lil bi**h and a new pump costs around $300 plus i can get some more power out of the motor without it the original right? it doesn't sound like too much work if you ask me
Old 04-03-2013, 04:50 PM
HRHohio's Avatar
Dusty bump... Anyone done anything like this yet?
Quick Reply: Electric power steering?
