Small Block & Big Block Chevy Specific - 8.1 liter
View Full Version : 8.1 liter
Bowlson
05-03-2011, 06:44 PM
:read: Do anyone know if the 8.1L vortec come with a forged crank and pistons
FiredUpZ28
05-03-2011, 08:02 PM
Well no response so I'll post my guess - I don't see why it would. Its a stump puller, cast iron can easily handle what its designed to do.
Parasoth
05-03-2011, 08:47 PM
From the interwebs:
The "first" marine 8.1L 496's came with a forged crankshaft... They later changed to a cast crank... Cant remember if it was just on the H.O version or not, but for sure there was a forged steel one made and run in production for the marine engine in the Mercruisers for a while
http://www.nautic-motors.fr/Engines.html
Look's like it was only the boat-moters that got forged crankshafts in the 8.1L. The L21 did get forged crank/pistons however.
Awake455
05-04-2011, 04:10 AM
L21 = 7.4L = electronic throttle coil near plug M.P.I. 454
Parasoth
05-04-2011, 11:59 PM
And? Could it be the OP maybe misheard which motor came with the forged assembly and I was throwing it out as to maybe clear it up for him?
http://www.ls1tech.com/forums/small-block-big-block-chevy-specific/794968-8100-vortec-lets-talk.html
There's a good thread thats on this forum even haha.
69chevelleSS
05-05-2011, 09:49 PM
Why buy a 8.1 truck engine?
Its a better idea to get a standard deck height 454 and go from there.
If I am not mistaken the 8.1 is a tall deck block which cost more to build and could cause a lot of problems depending on the car its going in. Just my 2 cents..
As far as it being forged I doubt if they are. Not meant to exceed 6000 rpm so there is no need from the factory.
Are you wanting to build off one or just asking?
69chevelleSS
93Z2871805
05-06-2011, 10:11 PM
Gen VII engines are their own animal (they're all metric too, iirc). I would go for a Gen VI or Mark IV to build.
twinturbo496
05-08-2011, 01:11 PM
You should investigate the connecting rod options before going very far with this, I believe the stock rods use 10 mm rod bolts.
Parasoth
05-08-2011, 02:38 PM
After reading the thread I posted I would stay away from that 8.1L as well.. heck you can even use a Gen 5 block if you can't find a Gen 6. The gaskets for mounting older/newer heads is the same cost as regular ones and it works fine.
