CTS-V brakes
Old 05-04-2011, 11:24 AM
DrunkieTheBear's Avatar
Default CTS-V brakes
...And I bet your thinking "Oh god, not another one of these threads." Oh but it isn't one of those threads. After seeing a thread on here about Z06 brakes, I did a lot of research for months on end and MANY MANY MANY phone calls later, I am able to present you all with results. Here is a link to the how-to and what not for what I did.
http://www.grandprixforums.net/offic...kes-46217.html
And just for the heck of it, so you don't have to click a link. Pictures:
Old 05-04-2011, 01:29 PM
Haulin_Ls4_GxP's Avatar
Good **** man very nice. What was the total cost.
Old 05-04-2011, 01:37 PM
Roughly around $600
Old 05-04-2011, 02:16 PM
I might have to do this. where did you get the rotors. Also it should clear the gxp wheels right?
Old 05-04-2011, 02:36 PM
Also what year did you get the calipers from.
Old 05-04-2011, 03:31 PM
ls4door's Avatar
Great success!! Does it 'ENDO'? Any solid performance numbers? Rough amount of feet it took off from 60? Repeated hammering. I have never had a problem with mine just curious! Looks very nice.
Old 05-04-2011, 04:01 PM
Panther427's Avatar
Now thats sexy
Old 05-04-2011, 04:55 PM
I doubt you will be able to run GXP wheels, offset is probably to high, I'm running 32mm offset wheels and they clear a concave wheel with about 8mm to spare.
I got my rotors from RockAuto. Centric Part number 12061089
2005 were mine, any year first gen CTS-V should do it.
These puppies grab and can engage ABS pretty easy if you really clamp down on them, and after numerous hits they still hold up fine (I run a nice brake fluid in my system). Also the break pedal feel is actually pretty nice, I have less brake pedal travel than when I ran a 12" Vette brake setup.
Old 05-04-2011, 05:48 PM
monte_with_a_LS4's Avatar
wow i cant believe someone actually did it!
Old 05-04-2011, 08:22 PM
07carlocrusader's Avatar
Yeah these look real nice!
Old 05-05-2011, 04:44 AM
blakss's Avatar
Finally someone did it! I was working onit to buh ran out of time, do you have part numbers and venders for the bushings and stuff like that?also how big are those rotors?
Old 05-05-2011, 07:31 AM
LS4:20's Avatar
All those calipers needs now are some GTP or GXP stickers! Lol
Old 05-05-2011, 10:22 AM
cacicgtp7's Avatar
I'm wondering how much "better" these are than the GXP PBR setup that comes from the factory. I mean I thought we had almost 13" rotors up front with 2 piston PBR calipers. I'm no genius but I thought the braking on our cars was pretty good to begin with...
Edit: I'm seeing this isn't on a GXP now so it makes more sense lol
Old 05-05-2011, 10:33 AM
Gxp brakes work very well. But adding 1 more inch to the rotor and two more pistons to the caliper would be even better.
Old 05-05-2011, 10:42 AM
GulfM3's Avatar
I have a set of 05 CTS-V calipers for sale if anyone is interested. PM me.
Old 05-05-2011, 03:16 PM
I have all part numbers in the link. It should be towards the top of the page with what you need, also a link to where you can buy the bushing.
I was thinking that Since I'm a Comp G, they will get some Comp G decals.
I had the C6Z51 Calipers before this setup and they were stopping my car about the same as my stock brakes maybe a little better, but these brakes actually give me less brake pedal travel (some of it is to do with the SS Lines) and clamp down hard. The added 1.3" and 2 more pistons will make a difference.
I plan to update that thread on GPF.net periodically, Wednesday I will post more pictures of how the Brake line is setup and couple other things, since I suck at pictures and some of them are blurry.
And as an added note, you could change out the CTS-V's for Z06's, but I'd put money that you need to have 19" wheels since I do believe they are a much larger caliper, but I'm not sure. CTS-V's are identical in bolt up to the G8 GXP/'10+ Camaro calipers, which are pretty much the same calipers actually, just different part and pad numbers, but use the same rotor size. Lastly Evo 8 & 9s Ran the exact same calipers as the CTS-V's so you could look for them as well.
Old 05-06-2011, 12:53 AM
blakss's Avatar
i got an 06 impala and im 99 percent sure that we have a 14mm bolt instead than the 12 mm on the older 12mm bolt so this might not be bolt up.at least without swapping spindles..
Old 05-06-2011, 07:15 AM
That is what the sleeve bushings are for.
You have the same spindle that every w-body from 97-present has.
-4 x 14MM bushing
McMaster-Carr
Part# 6679K16 Desc: Metric Steel-Backed PTFE-Coated Brnz Bearing for 12 mm Shaft Diameter, 15 mm Length Price: $2.45/each Qty: 4 (Grand Prix's have 14mm bolts and CTS-V's use 12mm Bolts)
Old 05-06-2011, 07:35 PM
Just an FYI you can get the same rotors at autozone for $23 less for each one
Old 05-07-2011, 02:52 AM
blakss's Avatar
I tried calling tha local autozones and the didnt even list it.. :/
And sorry I just saw that,and for some reason I thought the 06 and up had a diffrent spindle and used diffrent bolts but again you snapped big time!
Quick Reply: CTS-V brakes
