P0507 code
That code is for Idle Air Control Higher Than Expected. It sounds like you have a vacuum leak start check for that and check you IAC valve and TPS also. I have seen both of these cause this code and be sure to clean the throttle body good to the blade and the port where the IAC valve goes.
