No signal from ALDL (DLC) with engine running.
Old 05-04-2011, 04:16 PM
James Montigny's Avatar
Default No signal from ALDL (DLC) with engine running.
I have an 01 Camaro PCM
With the engine off / key on, I can read codes, see all of my sensors in real time.
I can even apply read/write using Winflash.
As soon as I start the engine, I lose connection and I can't get it back until I shut the car off.
The same code scanner works just fine on my Van and my Tahoe. (engine running or not)
I verified that pins 4 and 5 are grounded.
I verified that pin 16 is 12v (12.88 actually, just like the battery)
What am I missing?
Not being able to datalog is making tuning a real pain.
Old 05-05-2011, 12:08 AM
Figured it out.
Ed suggested that I unplug my alternator.
Sure enough ... the problem went away.
I'll get that repaired or replaced.
