Ngk Afx wideband
Old 05-04-2011, 09:17 PM
specialized.1's Avatar
Default Ngk Afx wideband
Which side header should I mount the sensor in? I hear one side might run leaner, or does it even matter? Has anyone mounted the gauge where the ASR swich resides?
Old 05-04-2011, 10:27 PM
SmokedOutZ28's Avatar
I have my sensor mounted on the driverside Y-pipe leg. I wanted to mount in at the end of the merge but there was not enough room. The display is mounted in the little cubby next to the lighter socket provided on the M6's Center console.
Old 05-07-2011, 08:06 PM
02SOMLS1WS6's Avatar
Did you have to modify that little pocket at all to make it fit?
Old 05-08-2011, 09:49 AM
Install finished. Mounted just above my right knee on velcro. Lots of wiring left in the car so I can move the gauge anywhere. Can't wait to drive this summer. Some might laugh, but summer starts a little late here.
Old 05-08-2011, 10:48 AM
Yes, Had to cut the back half off because it got narrower. Another route to take is to remove the cubby and have emblem pro's make you a plate to cover the hole left from the cubby and the wideband sits in the middle. I had them do that but broke it before I could even install it so i just decided to cut it.
Quick Reply: Ngk Afx wideband
