need power steering pressure line advice!
Old 05-05-2011, 02:15 AM
bmf5150's Avatar
Default need power steering pressure line advice!
hey guys need some advice,i bought nice braided line from street and performance to use on the pressure side of my power steering pump,but the line is leaking so i need a plan b so i can start this car this weekend..i have a ls1 with corvette power steering assembly.my power steering gear box is from a 3rd gen iroc.can i use compression fittings?will they hold the pressure?i could mate to different lines then.any cheap good solutions i can buy at a local parts store?
Old 05-05-2011, 05:35 AM
mramay's Avatar
Take the hose down to your local hydraulic hose shop and let them put the fittings on the hose. Shouldn't cost much and they won't leak.
Old 05-05-2011, 08:23 AM
c6matt's Avatar
3/8 compression fittings will work, I have used stainless parker ones sucessfully, I think my 4th gen camaro line trick would still work on the vette acc drive FWIW
Old 05-05-2011, 09:11 AM
99MUSTANG5.3L's Avatar
^^^this. I had a shop make up my entire hose for $37.
Old 05-05-2011, 10:14 AM
1981TA's Avatar
This was my backup plan, in case my original plan didn't work out. If you do happen to go into a Parker outlet, make sure to bring your end fittings or existing hoses with you. They normally do not stock the sort of ends typically used in automotive applications. I went to three different places in NW Indiana before getting pissed and making a new Corvette hose fit my old TA (see thread here: El-Cheapo PS Hose )
Old 05-05-2011, 10:16 AM
bmf5150's Avatar
Matt what u do with 4th gen line??
Old 05-05-2011, 11:34 AM
thunderstruck507's Avatar
I've been using a compression fitting to join the ls1 hardline to the stock chevelle hardline. As long as you get it tight enough it works great.
Old 05-05-2011, 07:11 PM
JIMB's Avatar
Aeroquip TFE lines work well. Designed for 3000 PSI.
Old 05-05-2011, 08:03 PM
bmf5150's Avatar
1981,where is Parker?not familiar with!
Old 05-05-2011, 09:23 PM
S10xGN's Avatar
Sounds like an assembly problem. Take a look here, right side of the page. The "tool" can be anything, it only needs to fray out the steel braids so the brass "olive" can fit between the steel and the teflon.
Old 05-05-2011, 09:36 PM
bmf5150's Avatar
I didn't realize it at first but the S&P lines is Teflon steal braided line!I went and bought a new fitting today!hopefully I can fix it tonight!
Old 05-05-2011, 11:05 PM
1981TA's Avatar
Parker is a manufacturer of high pressure hose items (fittings, hose, crimpers, etc). Local hydraulic shops usually carry a good amount of their stuff. This is an example of a local shop that carries their product line (good guys, by the way - very helpful)
Old 05-06-2011, 12:55 AM
bmf5150's Avatar
1981,u live in NW Indiana??
Old 05-06-2011, 07:27 AM
Old Geezer's Avatar
Had the guys at NAPA make my hoses...<$60.00
Old 05-06-2011, 10:09 AM
bmf5150's Avatar
I did not know napa does that
Old 05-06-2011, 11:08 PM
gMAG's Avatar
Ditto, here. They have all the fittings & line that you'll need.
Quick Reply: need power steering pressure line advice!
