Installing built LS3 into FBody, how to do PVC system?
I am installing a built LS3 into my 2001 Camaro SS.
I am using a slightly used stock short block and I might re-use my Pass Side LS1 Valve Cover.
Should I get a LS3 Pass Side Valve cover or modify my LS1 to make it work on the LS3 heads?
What parts do I need to redo my PCV system? What can I reuse? Any pics?
Do I have to use a catch can? Does the LS3 valley cover have a built in PCV valve?
Did a little searching but the info is so scattered, there should be a sticky for the procedure.
Bill
Bill
