computer tunning
Old 02-23-2004, 12:03 AM
stone150's Avatar
Default computer tunning
the car i am going to buy, 98 T/A, has computer dune to it where the the Egr is deleted out and the transmission shifing id firmed up and the timing is set ahead and the gear ratio is set up for 3:73s but has 3:23s in it, my question is if i buy a power programer can i set the stuff back to normal or will it just add on tomp of the programs thinking it is stock?
Old 02-23-2004, 12:09 AM
jrp
SN95 Director
jrp's Avatar
you can use an HPP3 to adj. the gear and shifting settings. the tuning option on the HHP3 power program bumps timing but i dont think you can seperately adj. timing. you cant do anything about the EGR with HPP3
i'd go with predator if you want a hand help programer or spend the money and get hp tuner or edit.
when tuning its best to start fresh, so i'd get your pcm reflashed with a stock tune and then go from there.
Old 02-23-2004, 12:13 AM
stone150's Avatar
how would i do that? and how much? bec that is what i want to do.
Old 02-23-2004, 12:29 AM
jrp
SN95 Director
jrp's Avatar
how much is what? a dealer reflash? 75 bucks IIRC. predator is 420 bucks and hp tuner is 500 bucks and edit 550.
Old 02-23-2004, 12:34 AM
stone150's Avatar
yeah i ment the reflash, the only thing i really want edited is the EGR, bec well, it dosen't have one, and then the spedobec of the gears.
